Topic: How to control Software playback volume by ARC ?
I wanna mapping software playback volume to arc.
How can i control it by arc’s wheel ?
Best regard
RME User Forum → TotalMix FX → How to control Software playback volume by ARC ?
Best regard
You can't. You control the Main or Phones outputs instead.
So you could assign the software playback channels to a phones output.
Thanks Matthias, that's what I thought. Could this be something you guys might consider adding in an update? Right now you can assign one of the remote control keys on the ARC to one of the Fader Groups, and have that fader group assigned to any fader. If you assigned that remote key to 'toggle', you could set it up that when you pushed that remote key, to toggle on the Fader group you assigned, that the Rotary Encoder only adjusts that fader, and not anything else its assigned to under "Default Encoder Function". Maybe???? That way you could control at least for different faders, or fader groups.
