Topic: Mic / Headset on ADI-2 Pro & ADI-2 DAC
Hi All,
likey a noob question, but i wasn't able to get firm answer anywhere.
I'd like to operate the ADI Pro as a high quality sound card on my Windows PC.
Would I be able to plug in and use my headdset mic (beyerdynamic MMX 300) for daily use?
Main prupose of course is high quality music, not Skype or chat.
Thank you for any hints
Norbert
2 (edited by ramses 2018-02-26 20:00:41)
Re: Mic / Headset on ADI-2 Pro & ADI-2 DAC
The ADI-2 Pro / DAC has no mic inputs.
But you can use it to listen to music as headphone.
The other thing is .. even if you had a recording Interface with Mic preamps ...
Such consumer headsets usually have a condenser mic which is not compatible with 48V Phantom Power (studio standard).
They work on much lower level and are only compatible to PC soundcards.
There are heaphones with a real condenser micros compatible to 48V phantom power available,
but then the headsets are usually much more expensive.
But as the ADI-2 Pro doesnt have Mic Preamps anyway, you can only use the phones for listening to music.
I would ask the manufacturer, what type of condenser mic this is and whether its compatible to 48V phantom power or not.
3 (edited by pianopictures 2018-02-26 20:15:50)
The short answer is no, you can't plug the mic directly into ADI-2 Pro. Although the mic in MMX 300 is rather strange, it is condenser one, but the manual says not to use phantom power from a mic pre (as you normally do with condensers), or you can damage it. My guess is that you need to use something like this in between:
https://www.musicstore.de/en_OE/EUR/Beh … 002535-000
But avoid using the +48 v phantom power in your case.
ADDED, I see we posted almost simultaneously with Ramses.
4 (edited by ramses 2018-02-26 20:19:32)
This I tried to explain, pls reread.
In his case he has no phantom power on the ADI-2 Pro / DAC. There are no mic inputs with these converters.
No problem wink
Thank you very much for your explanations. Appreciate it.
The Headset mic
Microphone Transducer type . . . . . . . . . . . . . . . . Condenser (back electret) Operating principle . . . . . . . . . . . . . Pressure gradient Polar Pattern . . . . . . . . . . . . . . . . . . Cardioid Power supply . . . . . . . . . . . . . . . . . . AB powering Supply voltage . . . . . . . . . . . . . . . . . 1.5 - 9 V Current consumption. . . . . . . . . . . . < 0.5 mA Nominal impedance. . . . . . . . . . . . . approx. 1.5 kΩ Open circuit voltage at f = 1 kHz . . . 20 mV / Pa Frequency response . . . . . . . . . . . . . 30 - 18,000 Hz T.H.D.. . . . . . . . . . . . . . . . . . . . . . . . 0.2% at f = 1 kHz Max. SPL . . . . . . . . . . . . . . . . . . . . . 120 dB Microphone output . . . . . . . . . . . . . unbalanced Dimensions Length mic boom. . . . . . . . . . . . . . . approx. 150 mm Capsule diameter. . . . . . . . . . . . . . . 13 mm Connection . . . . . . . . . . . . . . . . . . . Mini stereo jack plug (3.5 mm)
The German version says T-Power so totally different to phantom power.
So nothing i might use in any pro context as I understand.
Thank you. Learned a lot.
Kind regards, Norbert
Thats what I meant .. this mic is suited for PC soundcards
"1.5 - 9 V Current consumption"
Strange one indeed.
I figure the mic needs pip power, but Beyer uses "AB power". And that can't be true, since it is unbalanced.
