Topic: Phantom signal when using ADI-2 Pro's Analog Inputs?
When Analog Input is selected--and even if no signal is present or analog source is yet connected-- the RME ADI-2 Pro's "Analog Input" screen/display shows the presence of a signal which is depicted by a vertical bar centered at 25 HZ, raising to an about -33 db level. The lower part of the screen also shows levels for L & R (the two horizontal bars) each with separate values fluctuating independently (not the same) in the -65 to -77 (+ or -) dB ranges. I could sent a picture but I haven't figured out how to insert it.
Dr. L
