Topic: Fireface 802 and iPad Mini 2
I have a problem with my Fireface 802 and my iPad Mini 2: when I connect them via usb cable now a windows appears on the iPad' screen saying that the device isn't compatible with Fireface 802. It's weird 'cause time ago I was able to use it in this way. What happened?
No problems at all if I connect them via wifi.
Re: Fireface 802 and iPad Mini 2
Did you set the option for Set CC Mode on disconnect from the computer, in the TotalMix FX menu?
Thank you, it wasn't selected in the menu! Now it works again.
