Topic: Driving Avantone Mixcube from Babyface Pro
Hi
I'm looking to add a single avantone mixcube to my set up to check my mixes in mono. I was wondering if it is possible to connect using the 1/4" headphone out to the Mixcube and either summing to mono in Total mix before sending this out or if there would be a better way?
Re: Driving Avantone Mixcube from Babyface Pro
As long as the Mioxcube is active not passive that would work, otherwise you also need an Amp to technically drive the speaker as the one within the Babyface is only enough to drive headphones.
Excellent. Yes I was planning on getting the active mixcube not the passive. Thanks smile
