Topic: ADI-2 DAC grounding noise with Andromeda
Okay, this is crazy!
I just tested this in another room and the results are very surprising.
With no inputs or outputs connected to ADI-2 except Andro, I can hear a very low buzzing sound like when you touch an active RCA cable that goes to your amp.
What's REALLY weird, is that it changes depending on what I am touching, including the floor! If I lift my feet off the ground (tile), the hum is basically inaudible. If I place my feet squarely on the ground the hum increases. If I touch my hand to various other components connected on the same circuit the hum can be either slightly louder of very loud.
I know that you can use cheater plugs to lift the ground on some devices and this can fix the above problem but ADI-2 doesn't have a ground connection.
UPDATE: I was trying to use this as an AIO for convenience, but I decided to connect another amp (with a 3 prong power cable) using RCA and Voila! no more hum. I am still using the built in IEM output.
It seems like ADI-2 needs a better connection to ground to alleviate hum with sensitive speakers/IEMs.
I contemplated not posting this, as reading the beginning, it sounds ridiculous, but I hope others can learn from my findings.
