Topic: Arc USB with UCX
Is it possible in any way when changing volume in arc to get volume display to UCX?
When i have selected L1 volume i could see it on UCX. When i choose my snapshot, which is connected to the phones, it automatically goes to zero (below -64db) Then i have to adjust it in UCX, to select my PH level, every time.
Is it possible to get it changing automatically in UCX, when i select my snapshot in ARC?
Re: Arc USB with UCX
https://www.forum.rme-audio.de/viewtopi … 04#p130904
We had added this function to some newer devices where this was easy, but it is not possible to do this with units like the UC, UCX or Fireface 400, sorry.
But I don't understand this one: When i choose my snapshot, which is connected to the phones, it automatically goes to zero (below -64db)
It should only do so if it is saved like that in the Snapshot.
3 (edited by Bwoon 2018-05-05 10:37:40)
Thanks for the reply, i thought also that its older model issue, but i keep using arc anyway.
Its saved snapshot jes. You only can change volume, when its saved to the master out.
