Topic: Fireface UFX II problems with Bitwig Studio 2 Windows
Bitwig has a problem with the Fireface UFX ll. If I open the ASIO dialog from Bitwig and try to do changes, then the ASIO dialog freezes and I have to click a few times until the UFX setup dialog opens. And also If I save the changes in Bitwig, the ASIO Window in Bitwig again freezes and doesn't recognize the new setup unless I close and reopen Bitwig.
I have a project with 10 tacks 24/96 which with 128 samples of audio buffer is getting drop outs and crackles and with 256 samples just a bit better. CPU usage around 12%
With the older audio interface Focusrite Clarett 8Pre Thunderbolt I didn't have any problem. Surprisingly the same project works with 64 samples audio buffer without any drop out and crackle.
What I tried to fix that issue.
E clean installation of Windows 10 Pro, disabled all unnecessary features in Windows like antivirus, defender, graphically effects, set the CPU performance to high performance in the energy & power settings, set the processor scheduling to background services, deactivated the system sounds.... In the BIOS I disabled Hyperthreading, The Audio and Vt-d.
Installed the latest FF driver and the latest Bitwig version, connected the FireFace to the various USB ports, replaced a known good USB cable.....but still the same. (apart the keyboard and mouse, no other peripheral devices connected)
LatencyMon doesn't show any issue during the test.
My PC configuration: i7 7700K, Gigabyte GA-Z270X-UD5, 16 GB Ram Corsair 3000 Mhz, Samsung EVO 960, PSU b-Quiet 500 W.
The dealer nearby told me, that his configuration (Bitwig 2 and Babyface Pro) works fine and doesn't get any trouble.
Anybody an idea how can I fix the issues? A PCie USB Card from Sonnet with a Frisco Logic Chipset? (800€ vs 1999€ nice!)
