Topic: clocking 9652 and 4 different devices.
hey, I guess I need help.
I have a hdsp 9652, two behringer ada 8000, one behringer ada 8200 and one behringer src 2496.
the adas are connected to the 9652 via adat and the 2496 via spdif.
masterclock is the hdsp. everything is in sync.
is this a good idea or would it be better to clock everything from my main device which would be the ada 8200. can that be done over adat/spdif or would I need wordclock for this?
thanks!
Re: clocking 9652 and 4 different devices.
I would keep the HDSP as master, then all devices will just follow when you change sample rate, e.g. from 44 to 48, and you don't need to switch an external device.
thanks Daniel!
