1 (edited by ramses 2018-06-03 08:12:06)
Topic: Global record is missing channel descriptions, ...(Digicheck 5.91)
Channel descriptions missing:
If you select 2x UFX+ and 1x ADI-2 Pro in Global record, then you will notice, that channel descriptions are only present below the faders of the 1st row. For the 2nd and 3rd row they are missing. Without channel descriptions you are lost in regards to the amount of channels. It would be nice if this could be fixed.
Scrolling is kind of laggy, shortly interrupted
Its 1st of all a long way to scroll from left to right and while doing that its kind of laggy as the screen with the channels needs to be redrawn completely while scrolling.
Additional display options would be beneficial
1. Maybe it would be better to offer a 2nd option to scroll "screenfull" to the left and right or per 1 or 2 "Interface blocks" of either 8 Analog or 4 Mic, 8 ADAT, 8 MADI channels ...
2. Another interesting display mode could be to fill the Global Record screen with the complete number of channels of 1 interface and then to select between the, up to three, interfaces by using 3 buttons. This could be by having 3 buttons on top or bottom or by user selectable Function key or combination of keys (i.e. Ctrl-1, Ctrl-2, ...).
https://www.dropbox.com/s/ufezpff0i5swecg/2018-06-03-DIGICheck-Global%20Record.jpg?dl=1
https://www.dropbox.com/s/tclxjma6pc7z2pa/2018-06-03-DIGICheck-Global%20Record-2.jpg?dl=1
