Topic: TotalMix Volume Automation in ASIO Direct Monitoring
Hi everybody
I use Cubase 9.5 with a Fireface UCX and I have activated the ASIO Direct Monitoring.
If I disactivate the automation in Cubase, then the faders in TotalMix follow the actions done in the in the Cubase MixConsol : for example, if I add 3 dB on a track, the corresponding input in TotalMix moves of +3 dB.
If I activate the automation in Cubase, then the faders in TotalMix don’t follow the automation. They change only when I stop and replay the music. It seems that the commands are sent only when the music starts.
Is it normal?
How I can automate the TotalMix input faders with Cubase?
My needs are to use during live performance Cubase and TotalMix. For that, I need to be in Direct Monitoring (zero latency) but I would like to increase or decrease the level of the input automatically.
Thanks in advance
Philippe
