Topic: Internal connection to AEB8-O failing
Been an extremely happy user of RME PCI audio card with two AEB8-I and one AEB8-O expansion board for the past decade.
I believe after all the years the internal 2-wire cable of AEB-O is failing. When I turn on the computer the outputs only play static crackling noise.
Image of the wire I think is failing on page 4 here: http://www.rme-audio.de/old/english/dow … ebxo_e.pdf
When I take the cable off and put it back on again it sometimes fixes the problem.
Where can I find a replacement wire? Should I spray the connectors with something to try clean them?
Thank you!
