Topic: [BUG] Windows 10 installation failed
hello my name is benny i have a problem
I want to start the installation but I get the message that it failed
I tried to install it manual that did not work either, I ask for help!
my computer: WINDOWS 10 [64bit]
device: RME FIREFACE UFX
.LOG
INFO: ****************************************
INFO: Current working directory: 'C:\Users\b3nny\AppData\Local\Temp\rme'
INFO: Running on path 'C:\Users\b3nny\AppData\Local\Temp\rme'
INFO: User UI Language is 0x407.
INFO: Install option set: Force install if driver is not better.
INFO: Install option set: uninstall will be set to delete driver binaries.
INFO: Found driver package: 'C:\Users\b3nny\AppData\Local\Temp\rme\fireface_usb.inf'.
INFO: Preinstalling 'c:\users\b3nny\appdata\local\temp\rme\fireface_usb.inf' ...
INFO: ENTER: DriverPackagePreinstallW
SUCCESS:c:\users\b3nny\appdata\local\temp\rme\fireface_usb.inf is preinstalled.
INFO: RETURN: DriverPackagePreinstallW (0x0)
INFO: ENTER: DriverPackageGetPathW
INFO: RETURN: DriverPackageGetPathW (0x0)
INFO: ENTER: DriverPackageInstallW
INFO: Installing INF file 'c:\users\b3nny\appdata\local\temp\rme\fireface_usb.inf' (Plug and Play).
INFO: Looking for Model Section [Devices.NTAMD64]...
INFO: Installing devices with Id "USB\VID_0424&PID_3FC8&REV_0001" using INF "C:\WINDOWS\System32\DriverStore\FileRepository\fireface_usb.inf_amd64_b64fd7f20891cde7\fireface_usb.inf".
INFO: ENTER UpdateDriverForPlugAndPlayDevices...
ERROR: RETURN UpdateDriverForPlugAndPlayDevices. (Error code 0xE0000246: Einer der Installer für dieses Gerät kann die Installation zurzeit nicht ausführen.)
ERROR: Installation failed. (Error code 0xE0000246: Einer der Installer für dieses Gerät kann die Installation zurzeit nicht ausführen.)
ERROR: PnP Install failed. (Error code 0xE0000246: Einer der Installer für dieses Gerät kann die Installation zurzeit nicht ausführen.)
INFO: Attempting to rollback ...
INFO: No devices to rollback
INFO: RETURN: DriverPackageInstallW (0xE0000246)
INFO: ENTER: DriverPackageUninstallW
INFO: Uninstalling driver package c:\users\b3nny\appdata\local\temp\rme\fireface_usb.inf...
INFO: Successfully uninstalled 'C:\WINDOWS\INF\oem63.inf'.
INFO: No devices found for C:\WINDOWS\System32\DriverStore\FileRepository\fireface_usb.inf_amd64_b64fd7f20891cde7\fireface_usb.inf uninstall.
INFO: Successfully deleted properties for driver store entry 'C:\WINDOWS\System32\DriverStore\FileRepository\fireface_usb.inf_amd64_b64fd7f20891cde7\fireface_usb.inf'.
SUCCESS:Uninstall completed.
INFO: RETURN: DriverPackageUninstallW (0x0)
INFO: Wizard cancelled by user on welcome page.
INFO: Returning with code 0x80010000
INFO: 08/01/2018 17:25:58
thanks.
