Topic: UFX Noise Issue w/Video
This began as intermittent and originally thought it was a fluke but my UFX is now non-functional. Analog inputs are all squealing with digital noise. This issue occurs even when nothing but the power cable is connected - all other audio/FW/USB cabling is disconnected and the same issue occurs.
In the video the USB cable is connected just so I can demonstrate that the behavior resets or changes itself when loading workspaces but this issue exists with nothing connected. When this first began, loading a few random workspaces would stop the issue, then I could load the orignal WS and get back to work but that 'fix' no longer works.
https://www.youtube.com/watch?v=49_6-XcFq10
The issue has conincidentally occured at about the same age my FF800 died. The FF800 died at around the 5 year mark, that was the power supply which I subsequently rebuilt by hand to fix the issue - I'm not sure this is also a PSU issue but it's a little disconcerting that my second high-end RME device has failed with this frequency - it's getting a little expensive at this point.
Any suggestions? If there are any known issues that I can address/repair myself, please advise as I'm decently fluent in SMD reflow, soldering, PCB work and general electronics and microcontrollers - I'd really like to get this fixed since I can't justify purchasing 3 devices in 10 years due to hardware reliablity concerns.
FYI: Firmware, drivers etc. are all updated to the latest as far as I know (Firmware: 1.63)
