Topic: PCIe adapter for HDSP 9632
Can anyone recommend a PCIe to PCI adapter or another way of having my 9632 work with a motherboard that only has PCIe slots? I am looking at this one, any ideas if the 9632 would still work in it?
https://www.amazon.co.uk/dp/B0024CV3SA/ … _lig_dp_it
Thanks.
Re: PCIe adapter for HDSP 9632
This one works for me (HPSP-PCI + Multiface):
https://www.amazon.de/dp/B00EA04I2C/ref … l+pcie+pci
Multiface, Digiface, Raydat
Thanks, that one is not available in UK it seems. Will try my luck with the StarTech one.
Did you have issues with the 9632 fitting in, some people say they had to modify their PC case?
Sorry - I am unsing a HSDP-PCI card - which is much smaller than the 9632.
Just as an update if anyone is interested, the adapter works fine, no latency issues at all. Just to note, that because of the additional height when using this adapter, I'm not able to fasten the 9632 to the back panel of the PC (though the PCIe socket is plenty secure) and the 2nd breakout socket is now unavailable through the back panel but you may be able to modify your case to suit.
