Topic: Onkyo TX-8270
I bought Onkyo TX-8270, its internal DAC (AK4438 DAC) is not good even:
The TX-8270’s class-AB amplifier puts out 100Wpc into 8 ohms (20Hz-20kHz), and its AK4438 DAC supports up to 24-bit/192kHz PCM and FLAC, along with ALAC, WMA Lossless, and DSD 2.8 and 5.6MHz. It also features Onkyo’s Vector Linear Shaping Circuitry (VLSC), claimed to filter the audio output to “remove pulse noise generated in D/A conversion” and “reassemble the audio signal to its original form following processing.”
https://www.soundstagesimplifi.com/inde … o-receiver.
I think about buying your ADI-2 DAC.
What output XLR/RCA of DAC should I use for my Onkyo analog in (there is rca/cinch)?
