Topic: ADI-2 Pro ASIO Windows driver
How do I know if ASIO is working correctly with music players such as Foobar2000 with the ADI-2 when not having a ASIO plugin installed? Without the ASIO plugin Foobar just says the ADI-2 is a DirectSound output, with the ASIO plugin I can select the ASIO version of the Madiface aka ADI-2. But doesn't the ADI-2 Windows driver already apply system-wide ASIO support or am I wrong?
Cheers.
Re: ADI-2 Pro ASIO Windows driver
Yes wrong. Windows always uses normal audio drivers never Asio. You always have to select asio in the application. When it is a player or a DAW...
I see, thanks for the fast and concise answer, I'll keep this in mind for future reference.
Cheers!
You can make Windows Media Player ASIO aware wink
https://www.tonstudio-forum.de/blog/ind … ia-Player/
