The product description on webpage and handbook tell clearly 1x analog i/o, no mic preamps.
So you need a separate Mic Preamp for this purpose, either
a) QuadMic II to be connected via analog in (balanced) or
b) OctaMic II to be connected via ADAT IN which allows for up to 8 channels @44.1/48 kHz.
When going for a) you should get the optional analogue expansion board for inputs to be able to use all 4 Mic inputs of the QuadMic II.
Option a) would be also useful in cases where you want or need to reserve the ADAT port for optical SPDIF connection.
Option b) gives you more flexibility as the Octamic II inputs can be used as either Mic or Line inputs. The received signals will be send out via ADAT, line out and AES (4x AES out via breakout cable). Also nice, Gain knobs for every input and everything maintainable by front switches and Potis.
A more expensive as well as flexible option would be the investment into the Octamic XTC and to connect it via ADAT.
This gives you additional options like 2 additional phones output's, 4 x AES IN and OUT, ADAT IN and OUT.
XTC also supports MADI and can be used as format converter. Additionally it supports class compliant mode so that you can connect it directly to Windows or iPAD. So for an iPAD it can act as strong / flexible recording interface.
The phones outputs can also be used as unbalanced line output for ie speakers.
As it supports MADI the XTC can be integrated later into very nice MADI setups for very flexible solutions starting with ie a MADIface recording interface.
Therefore the XTC would be well invested money if you want to scale your solution later.
