Topic: Bug TM 1.50(3) / HDSPe MADI FX: AUX device limited to channel 1-128
I am unable to configure an Octamic XTC (#2) as AUX device which is connected to MADI3 (OPTO-X !!!) of the HDSPe MADI FX card.
In contrast to this the AUX Device configuration for XTC #1 on MADI2 works very well.
The key issue is, that the pulldown menue of
TM FX -> Settings -> Aux Devices -> Device Settings: Digital Channels
only shows "MADI 1-8" to "MADI 121-128" (this is MADI1 and MADI2), but nothing for MADI3 !
OS and drivers:
Windows 7 SP1 Professional
HDSPe MADI FX Driver v2.12
MADI Cabling:
MADI1-3: SC-SC MM OM4 DUPLEX 5M- 50/125µm
Summary of MADI devices connected to HDSPe MADI FX MADI1-3:
MADI1: UFX+, Driver 0.9673, HW Revision 49
MADI2: Octamic XTC #1, Firmware 26/47, Auto-CA, Compens ID: 1
MADI3: Octamic XTC #2, Firmware 26/47, Auto-CA, Compens ID: 1
HDSPe status / settings from driver configuration window:
Output Format:
MADI1: 64 (32/16) ch.
MADI2: 64 (32/16) ch.
MADI3: 64 (32/16) ch.
Input Status:
MADI1: Sync 44.1 kHz 48k Frame, 64 channels
MADI2: Sync 44.1 kHz 48k Frame, 64 channels
MADI3: Sync 44.1 kHz 48k Frame, 64 channels
Further settings details:
TM FX:
Digital Channels: MADI 65-72
Device: Octamic XTC
MIDI In: HDSPe FX MADI2 MIDI
Device ID:0
XTC #1 (where it works)
MIDI Device ID 0
Control: MADI In
USB MIDI 1: Off
USB MIDI 2: Off
MIDI DIN out: Off
MIDI ov. MADI: Control
XTC #2 (where it doesn't work):
MIDI Device ID 1
Control: MADI In
USB MIDI 1: Off
USB MIDI 2: Off
MIDI DIN out: Off
Overall status:
The channels of XTC #2 on MADI3 are visible in TM FX.
The MADI LED of all three devices is glowing.
Many thanks for further assistence.
