Topic: Digicheck on main output.
Hello, I'm trying to replicate the totalmix loopback to monitor the main output on digicheck in macos.
It's working as i do a hardware AES loop while in multichannel mode, but I'm only able to feed the AES out with the main levelled signal.
-Is there a way to have an option to feed the AES out with full level main signal ?
Or better, to have a loopback option without the need of hardware loop ?
-Is there somewhere i can see the current mode when Basic Mode is in Auto ?
-The analyser seems to show less high frequencies than the software Totalyser, is it the same tilt for both ?
-I find myself doing a lot of on and off on the auto-dark mode, can we have the Dark Mode (not auto) on a key ?
The power button would be my favourite with a quick press.
-I would like to have the ability to deactivate the pop-up witch is coming when adjusting level, it's very annoying when looking the screen to check spectrum or eq for example.
