Topic: No input signal in OSX 10.14 / Mojave, no TM FX out signal
In Mojave, access to the Microphone has to be explicitly granted for each audio app:
https://www.forum.rme-audio.de/viewtopic.php?id=27796
This includes DIGICheck, and on units where the FX are rendered by the computer (Babyface Pro) also TotalMix FX. Here the FX output stays silent/dead as long as TM FX is not allowed to access the 'microphone'.
2 (edited by Jiser 2020-02-01 00:19:12)
Re: No input signal in OSX 10.14 / Mojave, no TM FX out signal
Thank you so much !
that was my solution big_smile
all working right now
Vielen Dank
I wrote on the support site and they redirected me to this forum. I hope you can help me.
I just bought a Fireface UCX and installed the drivers 3.19 for Mac OS Catalina.
Once installed (successfully I thought, with the manually procedure for the newest Mac security system), I cannot hear sounds from de analog inputs, neither the 3/4/5/6 channels or the MIC/Line input, but I see clearly that the signal arrives to the Fireface (light on "SIG" pilot) and also to the computer (movement on faders on TotalMix). I tried to apply the solution on this topic, but it didn't work for me, as the Fireface doesn't appear as an app that is asking for use the Microphone. I followed the route System Preferences>Security and Privacy>Microphone, and tried to search the Fireface but there is no result. I have also selected in System Preferences  the Fireface as Input and Output Sound device.
Thank you in advance.
You don't select the audio interface but the application that you use for recording.
