Topic: Is 'Enable MMCSS for ASIO' still recommended for Cubase 10?
I was wondering after Steinberg optimized Cubase 10 for multicore/multi-threading, should the Enable MMCSS for ASIO still be used?  The manual still recommends it for Cubase and says it is easy to compare and test checked versus unchecked, but I am not sure how to test this.
Any info on either point would be appreciated.
Thanks.
FireFace800 (D 3.125, fw 2.77) Ryzen9 3950X, 570X Extrm4,  Win10 Prox64 1909, 32Gb DDR4-3600, GTX950
Re: Is 'Enable MMCSS for ASIO' still recommended for Cubase 10?
Bigger project, lower ASIO buffer size.
At a certain point you should eventually be able to validate / toggle to have audio loss when not using MMCSS.
