Topic: RME driver corrupts Audio and MIDI setup on High Sierra
I just installed the driver for my RME FW800 in my new macbook pro.
The installation is successful and I can use the RME.
Once I disconnect the RME from the laptop the Audio and MIDI setup crashes with this message:
The MIDI Server can’t be opened.
Audio MIDI Setup couldn’t open the MIDI Server so you can’t view or edit your MIDI configurations.
If you recently installed a new MIDI driver, try uninstalling it and then open Audio MIDI Setup again. If Audio MIDI Setup works correctly after that, contact the driver’s manufacturer for further support.
Any DAW (Logic, Ableton Live, Reaper) hangs for long time until it throws an error and starts...
Version info:
OS version: High Sierra version 10.13.6 (17G2307)
FW8000 Driver: fireface_x86_275.zip
Is there a procedure to uninstall completely the driver?
Is there the possibility to have this problem fixed?
Thank you all
Daniele
