Topic: RME UCX channel 3 & 4 not sending audio to windows?
Hi I'm new here!
I am experiencing a strange problem with my RME UCX. I have an input (a dynamic microphone) connected to the front of the unit in either channel 3 or channel 4. The signal from the mic is being picked up by TotalMixFX. The DB meter shows a signal when I speak through the mic, and I can also route the signal through my headphones and it sounds absolutely fine. However, when I select Analog 3 or Analog 4 in my DAW (tried both Cubase and FL-Studio 12.1), the DAW does not recieve a signal. When I plug the dynamic mic into channel 1 or 2 at the front, and try to select Analog 1 or Analog 2 in the DAW, the signal does come through and everything seems to be fine.
At first I thought this was a DAW problem, so I tried to see if I could get a signal in the windows sound overview (control panel -> sound -> recording). Here I see the same thing. When the mic is connected to input 1 or input 2, the signal comes through fine, as the green bars rise when I speak through the microphone in the windows sound overview. When I then connect the microphone to input 3 or 4, set the gain properly in TotalMixFX, and then look at the sound overview, no signal is coming throug at input 3 or 4...
So the audio on input 3 & 4 is picked up by TotalMix FX, but I cannot find the signal in any other program including the Windows sound overview. It seems as if TotalMixFX doesn't route the audio to the OS...? (this is my assumption, but I'm no expert on this)
I have already tried several things to fix this:
I restarted the unit and my computer.
I've updated to the latest UCX driver (I'm now on 1.166).
I've unplugged and replugged the UCX Usb cable.
I've tried a different USB port on the computer.
None of the above has resolved the issue. I'm desperate for a solution, maybe anyone here has an idea of what to do?
Thank you in advance!
Technical information:
OS: Windows 10 pro 64 bit;
PC: I7 5280K, GTX980 TI, 32 GB Vengance 1600 Mhz Ram, MSI Gaming X99A motherboard, Samsung 240 EVO SSD;
INTERFACE: RME UCX revision 46 running driver 1.166;
MIC USED: Shure SM58;
DAWS: Cubase 9.5.40; FL-Studio 12.1.3 64 bit;
