Topic: More scalability in TotalMix GUI?
So at this point, there's 3 options for window size...100%, 135% and 200%. Unfortunately that's not cutting it with all the options for monitor size and resolutions today. Is RME planning on increasing the options for scalability?
Thanks, G
MacPro 2013, 10.12.4, 128GB ram, and two other MacPro slaves
Cubase10
UFX+ ARC USB remote
Re: More scalability in TotalMix GUI?
If you use a Mac that has a higher resolution then 270% will also be available in the menu. That's cutting it quite well.
Hi Matthias,  I am on a late 2013 Mac Pro and I don't see 270% listed. I have TotalMix 1.5. The only other options I see is 'Enter Full Screen' which doesn't do anything, and Zoom which expands everything horizontally to fit the monitor. So on my 38" with 3840x1600 resolution, 135% is a little small and 200% is cut off at the bottom, which is why a few more options would be nice.
Thanks, G
Cubase10
UFX+ ARC USB remote
