Topic: RME ADI 2 PRO in multichannel (USD interface mode)
Good Day chaps.
Happy new year.
I am trying to use the unit as a 2 in 6 out for music production in USB mode
1 / 2 in – recording
1 / 2 out – playback
3 / 4 out – outbound signal A from DAW
AES out – outbound signal B from DAW
Just so you can understand what I am trying to achieve, I am trying to take signal A out then run it into a sidechain of an analogue compressor. Then take signal B and run that into the input of the compressor. I wish to then take the output of the compressor into 1 / 2 recording [using only 1 mono]
My digital audio workstation is recognising all outputs and inputs as stereo pairs and as separated mono.
However, when plugging in my converter cable I immediately get both AES and SPDIF output signal replicated from output 1/2?
>I attach an image for your convenience.
I have read the manual excessively but I just cannot seem to find the solution to how all 8 outputs/6inputs are independently separated in USB mode.
To my understanding this can be done directly from RME adi2PRO to USB without any need for additional hardware.
I am successfully able to use analogue 3/4 as an output (TS front headphone out [left socket])
I just cannot get AES out to function as a separate output channel for a separate signal from DAW
Looking forward to your assistance. I am really stuck sad
Re: RME ADI 2 PRO in multichannel (USD interface mode)
image for you here guys
http://powch.org/rmeadi2pro.jpg
Hi, maybe you need to set class-compliant mode to multichannel?
