Topic: TotalMix MIDI control map
Is there anyway to freely map the faders and buttons in TotalMix to your desired midi CC:s? Now they all are hardcoded and you have to adapt your controller to map to those hardcoded values in TotalMix. In my mind it would be way better design if you could freely map the midi CC numbers within TotalMix. This way you could for example control two TotalMix faders with single button from your midi controller.
Is this free midi map a feature that you could consider?
Also another question: if I have hardware input 1/2, how can I control input 1/2 to output 3/4 volume with midi? I can only control the 1/2 in to 1/2 out fader, not 3/4 out.
