Topic: Just a couple of questions from a beginner
Hi all, I'm set on buying the ADI-2 DAC today and have read the manual and forum in preparation. I'm a little unsure on a couple of points so I thought I'd ask.
Firstly I'm not sure where to source an XLR to RCA cable that has pin 3 disconnected, as per the manual. I saw a thread on here about the same matter but the links to suitable products are now dead. I'm in the UK and I'm having a hard time finding a suitable lead, so if anyone could point me in the right direction I'd appreciate it. I'd like to run the RCA out to a headphone tube amp and run XLR out unbalanced to my speaker amp.
Second is that I'm a bit confused as to what output settings I should use for my speaker amp. I have the option on that amp to change a source's RCA input voltage to 4V, but obviously the ADI-2 has variable output too. What settings would be optimal in this situation?
Third is just a question of how often shipped units are flashed with the latest firmware. I have no access to a PC at the moment so would be unable to update the ADI-2 for a while. The dealer - Juno Records - said that the units were only just received in January so are likely to have the latest revision on them, is this the case?
I think that's it for now, thanks in advance for your help.
Re: Just a couple of questions from a beginner
Regarding the XLR to RCA cable you could try designacable.com
The people there make custom cables and connectors. Their website can be tough to navigate, so it is probably best to just tell them what you are looking for and they'll build it for you.
Kind Regards
Rodney Ferguson
Rme Ucx + Rme Adi-2 Dac Fs
3
Give Synthax UK a call. Such cables are usually easy to get, but as I am not in the UK I can't help.
You should set your speaker amp to the highest voltage (= lowest sensitivity)  available. The DAC can handle it all. Doing so you minimize noise, hum, mega volume surprises etc.
Thanks Rodney and Matthias, I'll see if I can source some cables from one of the places you suggested. Could you clarify the output settings needed for XLRs running to the speaker amp's RCA inputs, set to 4v as you advise? Am I right in thinking that converting a balanced signal to unbalanced will affect the power my amp receives? If so, what reference level should I choose to maximise the SNR? I'll be using the outputs as fixed.
Just to repeat my query about the firmware a unit received in the UK in January might have - do you update units to the latest firmware before dispatch? There's some great features that have been added since the product's release and it'd be fab if it was up to date out of the box. Thanks again for your help.
5 (edited by Curt962 2019-01-13 23:36:44)
JP,
I received my new ADI-2 DAC on 28 Dec here in the US.    It was loaded with Firmware 21.
There were several FW updates done in Late December which explains how this can be so.  My Unit was simply in-transit.
FW Updates are remarkably Pain-Free, so you'll have no difficulties!! (Visit the RME Website for the Newest Drivers)
This is a fantastic unit, and Trust you will be Delighted!
Curt
Cables:  Red, and White Ones.
Speakers:  Yes
Thanks Curt, I placed my order so it should arrive on Tuesday with a bit of luck and a following wind. It's not a big deal which firmware it's running, it's just I'm without a (working) PC at home and installing programs at work is out the question so I guess I'll just have to beg, borrow or steal a laptop from a friend or family member. Either way I'm looking forward to taking delivery, the specs on the unit are top tier and I've never seen one so versatile. I'm glad you're enjoying yours! smile
I found a company to make me a cable (tha ks for the help) so what I actually need to know now is what power the balanced outs produce when wired as advised. Is it the equivalent of 2v so they can be treated like the unbalanced outputs? I'll be setting them as fixed outputs, I need them to be the same volume as the (also fixed) RCA's, but I'm genuinely confused what output setting I need to use.
I think I'm correct that +7dBu with the volume set to 0 is correct for the RCA outputs (I won't be using auto reference levelling) but I'm stumped what dBu setting the XLRs should be set to with the volume at 0, especially if I set my amp to 4v as was recommended. If you could help me out with that I'd really appreciate it, I've Googled my fingers off and I'm still none the wiser. Thanks once again!.
(by the way - you realise that this is what you get when you release professional quality equipment to home users - idiots like me!)
7 (edited by N00b 2019-01-14 11:32:37)
Like Matthias said, set your amp to the lowest sensitivity (highest voltage).
Then, on the ADI-2, to keep it simple, you can turn on the Auto Ref function on and set the volume right (starting by the lowest volume).
Your ADI will switch automatically between the different output levels and you won't have to bother. wink
And if you wan't more info between dBu, voltages etc. : http://www.sengpielaudio.com/calculator-db-volt.htm
JP,
As an equally new RME User, I simply let "Auto Ref Level" feature worry about the Math.   The User Manual discusses the matter in far greater detail than I can.
Much as you, I'm using my ADI-2 to drive Active Speakers, and Subs.   No headphones involved.    Given that Ambient Noise levels in even a Quiet Room are surprisingly high, that LAST DB of SNR may go un-noticed.
Let Auto-Ref get you started, I'd Wager you'll be pleased right there.
All the Best!
Curt
Speakers:  Yes
Thanks guys, I think from your responses I'm obviously sweating the details too much - the unit is clearly far cleverer than I am so I'll let it do its work (at least until I understand exactly what's going on - I'm determined to get my head around it!). Thanks for the link, N00b, I'll check it out and hopefully the mist will clear.
Using the DAC straight to monitors and a sub? I bet it sounds phenomenal, Curt. I'll be using it primarily for headphones as I couldn't find a DAC/amp that was anywhere near as clean and versatile. However, you're right, with it driving my stereo setup too, extracting every possible dB of SNR isn't that important at all - my amp, speakers and ears are the bottleneck!. I think I got a bit hung up on the numbers. Let's call it over-excitement!.
Thanks again guys, with a bit of luck this'll be the last time you hear from me. But don't count on it smile
10 (edited by Curt962 2019-01-14 18:26:02)
JP,
Don't judge yourself too harshly.  You cannot possibly be any more of an RME Beginner, than I.
Tomorrow is the Big Day??  I hope your New DAC arrives on-time.   Enjoy!
Speakers:  Yes
It's just me, I'm back!. It arrived on time and despite the initial intimidation of that menu system I've got it dialled in perfectly for all my headphones and the external amps too. It arrived with firmware 22, I'm thinking about getting a Windows tablet to update it and run my music from. It's a fantastic unit, the difference between it and my previous gear is clear. It beats my old headphone setup hollow and the DAC feeds my amps better than anything I've tried.
There's one issue that is bugging me and I'm struggling to find a solution. When using 12ohm IEM's I can hear interference. It's quiet but it's there with any source, and it changes depending on where and how I position the power supply. I can sometimes get it so it's silent, but then it comes back. I popped some ferrite core suppressors on and it did help a little (I think, it's difficult to tell), it's running through one of those Tacima strips (although I don't put a lot of stock in it) and despite my best efforts to isolate the wiring I just can't eliminate the interference for good.
What's the best way to have the cable in terms of coiled vs straightened? The lead only needs to run a foot or so from the socket so I've tended to leave the thin wire to the DAC coiled with a suppressor around it. Should I uncoil that? Would shortening the figure of 8 mains wire help? Or coil that up?. It's not a huge deal, but hearing interference between songs or in quiet passages is a bit distracting, especially now I've heard how ghostly quiet it can be when it's all working perfectly, it's really remarkable. I've removed as many other appliances and plugs from around it as possible, there's essentially just the ADI-2 running off that Tacima.
Any hints and tips? Once I can get this sorted it'll be absolutely perfect smile
12
You need to check the whole setup.
Is the Phones out set to Lo Power?
What happens if you reverse the power supply plug?
Are we talking about the ADI's power supply?
What is connected to the ADI, and what happens to the interference if you disconnect USB or SPDIF coax or RCA? It goes away. So there is a ground loop between the devices and you need to break it.
The IEM output is set to low power - in fact it can't be set to high power, at least not on this firmware. The power supply plug can't be reversed at the power end in the UK, but I reversed the figure of 8 end and it's no different. Yes I'm using the power supply that came supplied with the unit. I just unplugged everything except the power and the interference is still there (it sounds like faint static). Depending on where I route and place the wires and SMPS I can increase or reduce the static. I've found a spot where it's minimised, but it is still present. It's definitely not a ground loop.
14
Ok, DAC IEM does not have low power option.
We had such a case before, electrical ground was missing. You should connect the DAC's ground (ground terminals or housing) to something that is well grounded. Then the interference will be gone.
Old school eh? Okay, I'll give it a try tomorrow, I'll have to dig some speaker cable out, there's copper piping nearby so it'll be easy enough.
I'm afraid that didn't work, I had the unit grounded to a copper water pipe and I could still hear interference. The power supply is apparently just picking up RFI/EMI and passing it straight through. I have other supplies I could try - to eliminate the supplied PSU being the cause - but frankly I don't want to plug any others in or risk my warranty. At the moment I have the DAC, cables and SMPS positioned so it's rare and barely noticable so I'll make do with that. Perhaps when I rearrange my room and equipment I'll be able to shield the supply/cables from whatever they're picking up. Cheers for your help anyway.
17
That is astonishing. Does the interference change when you touch the unit's housing?
The ADI runs with many standard power supplies as long as they are in the range of 9 to 15 Volts and supply at least 1A. Important is the polarity on the connector, + inner pin. So if you have something that matches simply try it.
18 (edited by JustPoo 2019-01-26 00:47:18)
Hi, I'm sorry for the delay in replying but I had no notification of your response, I was just browsing the forum again to see if there was any news. The interference didn't change when I touched the device, the only way it changes is if I move the supplied power supply or wires. I'm as surprised as you that grounding the DAC didn't help, at least a little. With the PSU supplied I had everything positioned so that interference was pretty much eliminated, but if I moved the supply the problem would return.
As you gave me the go ahead to try different supplies I now have it set up with another 12v SMPS and that's eliminated the issue entirely, I can't hear it with my most sensitive IEM's. The supply is nothing special, it's a larger 10A unit, but it does seem to have better screening. It doesn't matter where I place the wires or SMPS itself now.
So the problem is solved, I'm not a believer in special "audiophile" power supplies, and this replacement certainly isn't one of those. It could simply be that there's a problem with the supplied power supply unit. I'm glad I came back to the forum now - I registered the 5yr warranty (very reassuring) and I didn't want go plugging in anything that could jeopardise that, especially when I had already reduced the issue to barely noticeable by just moving the power supply around. I feel better now it's totally solved though!
Just edited to add that it would be useful to make more use of the buttons on the device. For instance, clicking the volume knob does nothing normally - it would be good if that could be configurable; to mute the device or similar. Long presses on buttons could be used as shortcuts to other functions too. I've learned how to navigate my way around the menus quite quickly now but still, instant access to the more used functions would be handy. Perhaps that's something you might consider in upcoming firmware updates. I updated the unit to the latest firmware the other day (actually, I borrowed a laptop, had to fix the laptop, and then updated the firmware!) and appreciate the little tweaks, it's one of the reasons I chose this device over others as it seems to receive worthwhile upgrades. Anyhow, problem solved, I'll check back on here soon. Take care.
19
See manual.
See manual smile
Ah, thank you, I see what you've done there, I did wonder why the remote remap screen looked like that!. Doh. Looks like you were way ahead of me already, I'm still learning what this puppy can do!.
Just a suggestion - I think it might be good to be able to seperately assign the programmable 1-4 buttons on the remote from the buttons on the unit. At the moment if I remap "Vol" to "Mute" then I've wasted button number 1 on the remote, because it already has a mute button. Being able to map the knobs for long and short presses would be handy too, especially the nice big volume knob - it'd be great to prod that once for dim or longer for mute. Not sure what extra shortcuts could be added to the list but perhaps that could be expanded? That's the joy of it being an updatable device, it's as versatile as you guys want to make it. And that's the joy of being me - I can just chuck ideas out without the slightest notion of how difficult they are to implement! smile
I just this minute managed to accidentally create a group loop. I'm typing this reply on my phone while I watch a film (A Quiet Place - not ideal bedtime viewing!). I was listening through the RME and some IEM's. I paused the film and noticed that distinctive ground loop hum noise, the first I've ever heard from it. I grounded the unit with my finger to eliminate the hum, figured I might have to wire it to the pipe after all. I put my phone down to grab some wire and the hum immediately stopped. Picked my phone up again - hum. Took me a second before I realised I had it plugged in. That'll teach me, it's protective silicone cases for me!. Night night smile
