1 (edited by djfrankieflowers 2019-01-28 23:00:10)
Topic: Real Player mp3 playback issue
Hello.
My Fireface 800 has the sample rate set on 44100 but playback is slowed down to almost zero when I play an mp3 with Real Player. It is obviously a playback sample rate issue. It doesn't happen tho when I use my 410 M-audio.
Please help.
Re: Real Player mp3 playback issue
You should give more information about your setup.
Operating System / Version, FF800 firmware / driver version, real player version.
As real-player appears to have no ASIO support, what driver are you using ?
Did you configure RME WDM devices in the driver settings dialog ?
Are you using the RME WDM devices with Real-Player ?
