1 (edited by JES 2019-01-29 03:01:03)
Topic: Babyface as ADAT client?
Greetings.  I'm looking to increase my number of inputs and outputs, and to hook up several ADAT interfaces.  Would it be possible to run a Digiface out of my computer, and use one set of ADATs to connect a Babyface running in standalone mode as a convertor?
If so, could I run it as a monitor station, to switch between headphones and monitors?  (That's mostly how I use it now).
Thank you.
Re: Babyface as ADAT client?
You won't get the full 8 ADAT channels out of the BF....
3 (edited by JES 2019-01-29 15:28:17)
Thanks.  I know that's a limitation, but can I use the 4 channels it has as outs, and can I switch between headphones out and speaker out using the top panel in standalone mode?
There is no output 'switching' in stand-alone mode. Only volume control of each.
