Topic: UCX - power on with display in level mode
Hello! Some time ago I built a device based on the arduino which is able to receiving messages from the IR remote control and converting them into MIDI messages, to be able to control the RME UCX output volume (it also controls relays that power on/off the UCX and audio monitors). My only concern is to make the output level appear on the display immediately after running the UCX (now I have to press knob twice to get level on display, because I can't achieve it remotely). Is it possible to set UCX so that the display will be in the output level display mode after turning on? Or maybe it is possible to switch the display mode by sending appropriate MIDI message? Thank you in advance for any helpful answer.
Re: UCX - power on with display in level mode
Not possible, sorry.
Can you consider this function/ability in the future version of the software/firmware?
