Topic: does multiface 1 work with an HDSPe ExpressBusCard
I 've using the multiface 1 untill now with an PCMICA bus card on my laptop
but I will change to another laptop, wich does not have that bus card adapter, but an express card adapter
this one:
http://www.rme-audio.de/en/products/hds … sscard.php
greetings
jan
Re: does multiface 1 work with an HDSPe ExpressBusCard
Yes, it works. But the HDSPe ExpressCard is also discontinued now, so not widely available.
thanks for the info.
in case I can not find a HDSPe ExpressCard, is it a good idea to use a Digiface to connect to the laptop and
use my multiface ADAT out into the Digiface? in case this works, will there be more latency?
greetings
jan
The multiface needs a computer to set it to work. If you leave it powered on it will still work without a computer but as soon as it is powered off it will lose it settings and stop working and will need a computer again to work (you can use your old laptop for this).
I think there are also expresscard to pcmcia adapters to make the current pcmcia one work with a new laptop. Startech has one for sure.
vincent, thanks for the info.
I will look for an expresscard, if no succes, looking for a expresscard to pcmcia adapter
greetings
jan
hello RME
I recieved an expresscardbus, but it say HDSPe Madiface expressCard/34slot, only to be used with RME's Madiface.
will this work with a Multiface I ?
Sorry, no.
jan
