Topic: Audio glitches with UC and MacBook Pro 2015
Hello there,
I have read about the problems with 2018 MacBook Pros and USB2 connection in another thread in this forum, and recently also on heise.de. I think I have a quite similar issue with my MacBook Pro 13" 2015.
I'm using
MacBook Pro 13" 2015 with 2,7 GHz Core i5
RAM: 8 GB 1867 MHz DDR3
128 GB SSDFireface UC connected to USB3 connector on the MacBook directly (left side)
256 GB Samsung SSD T5 USB connected via ANKER USB 3.0 HUB to the MacBook Pro (right side)
OSX Mojave 10.14.3
Latest RME driver version
I am running
Ableton Live 10
Native Instrument Komplete 11, samples are saved on the external Samsung SSD T5
Now the problem: The Fireface UC has audio glitches
when I'm using 44,1 kHz and 128 Samples, even if I only use one track with Komplete Kontrol VST or a standard instrument from Ableton.
44,1 kHz and 64 Samples is not useable at all, it's horrible with this setting and the playback is slower...
With 44,1 kHz or 48kHz and 256 Samples I get no glitches but that is rather high setting for performing live.
at 88,2 kHz I need 512 Samples
at 96 kHz it must be set to 1024 Samples.
The Konsole gives the following error:
standard 18:45:57.533139 +0100 coreaudiod HALS_IOContextDescription.cpp:1113:PushStreamUsageToEngines_block_invoke: IOContext 134: pushing 3 output stream(s) to 'de_RME_driver_USBAudioEngine:16A3A09'
So the lowest settings that I can use are:
44,1 kHz with 256 Samples
48 kHz with 256 Samples
88,2 kHz with 512 Samples
96 kHz with 1024 Samples
What is the problem here? What can I do to run with lower Sample rates?
