Topic: Any way to input 5.1 via optical cable?
I'm connecting a 5.1 system to my FF800 via optical cable and it seems I can only input the first two channels... which becomes very problematic at least when the center channel is used and then lost in translation.
Am I missing a feature or the signal is irremediably restricted to the first two channels only?
Thanks!
A dood from Steinberg
Re: Any way to input 5.1 via optical cable?
The FF800 can not decode DTS/AC3 signals...
Hi Daniel,
Alright then it's all cleared up. Could I ask you which one of your interfaces does by any chance?
Cheers
None. That requires a special chip which you usually find in HiFi AV Receivers.
Ok so I guess the best is to have such system making the connection between my original DTS source and the FF800. Thanks!
