Topic: Clicks and pops after Windows 10 upgrade
So I finally bit the bullet and upgraded to Windows 10 Pro 64 from Win7x64 (partly to fix RX7 which wasn't working) and now I have lots of clicks and pops when I playback anything in Cubase with my previous settings. Oddly, Ableton Live 10 and Cakewalk don't have this issue after the upgrade, although I detected one or two clicks in a large Reason project.
At first it was quite bad. Even with a completely empty project loaded and not playing the real time peak meter was averaging about 50 percent and was spiking pretty frequently. So I did a little searching here and found a few suggestions. I disabled every Windows service that I knew wasn't necessary and got my load down to 1.6 Gb RAM (with Cubase closed). That helped some but not enough. Then I saw the suggestion to change the Processing Precision from 64 bit to 32 bit. That helped quite a bit more and now I can play a 3 minute piece and only hear 3 or 4 clicks during the whole playback, but I heard none before upgrading and this is the same project with the same hardware, just the OS upgrade.
I have Steinberg Audio Power scheme enabled, and ASIO Guard set to Normal. Under Windows 7, I was able to play back projects at 64 samples, now I have to increase that to 256 to get clean playback.
Anything thing I'm missing? Any help would be appreciated. System specs in my signature.
Thanks.
FireFace800 (D 3.125, fw 2.77) Ryzen9 3950X, 570X Extrm4,  Win10 Prox64 1909, 32Gb DDR4-3600, GTX950
2 (edited by ramses 2019-03-04 07:22:13)
Re: Clicks and pops after Windows 10 upgrade
Perhaps this helps ?
https://www.studio1productions.com/Arti … wire-1.htm
Just for the records..
Which Win10 release ? 1803, 1809 ?
Which Firewire chip is on your card ?
3 (edited by SF_Green 2019-03-12 19:03:37)
Yes, that did it!  Thanks!
Also, I am 1809 release of Win 10, and have a SIIG TI chip FW card.
Nice to hear wink
