Topic: 2 Questions about ADI-2 DAC
I have 2 questions about the ADI-2 DAC:
1,
Is it possible to get the volume level meters on the unit to show the level of the incoming signal?
Mine shows the level of the outgoing signal and it only matches the Digicheck levels when I have set the units volume to 0db obviously. The Spectrum Analyzer on the other hand always show the levels of the incoming signal and matches Digicheck perfectly at all times. It would be great to be able to see the exact volume (dbfs) levels of the incoming signal as I am using the unit in a mastering chain.
2,
Pressing the big volume knob doesn't do anything. Is there a way to map anything to this function? (Mute would be great.)
Many thanks.
