Topic: HDSP-9632 + ADI-2 = no audio output?
Hi I just moved this hardware from one computer to another, and apparently I've set it up incorrectly on the new computer. (It was working fine before.)
Everything looks good except there's no audio coming out of the ADI-2. There's light coming from the optical cable (from the HDSP-9632). But there's no signal registering on the ADI-2's meters.
Audio is coming in from the ADI-2 into the HDSP-9632. I can use it to record. But I can't get sound from the ADI-2.
TotalMix is registering the audio on Analog 1/2 and Main. But again, it's not registering on the ADI-2's meter. The optical cable is physically plugged in correctly.
edit:
a couple more details: there's no blinking lights on the ADI-2. So I assume clock-lock between the ADI-2 and the HDSP-9632 is happy? It's set like usual to Clock 48; Input: OPT; Output: ADAT. Also, audio is successfully coming from the TRS(F) output of the breakout cable from the HDSP-9632.
