Topic: 2 channel stereo with 2 mono subs setup with RME Adi 2 pro
Hello, I have the following question:
If I generate a 2.2 correction filter (with Audiolense or Acourate), that is two stereo channels plus two subs (with crossover at 80 hz), will I be able to play all the four channels with the Adi 2 pro? Can I properly route the four channels to the four analog outputs available in the Adi 2 pro if I set the ccmode as multichannel?
Has anybody any experience with this kind of set-up?
