1 (edited by ahus84 2019-03-03 22:36:18)
Topic: Noise on Babyface Pro
I give gain on Analog Ch 1/2, or independent (Ch 1 or Ch 2), and I got a nasty noise (it is sort of a pink noise, but without the low/mid-low end). It starts to get more notorious from +25dB and up, on the preamp (internal from babyface pro).
I do not have any microphones pluged. But when I do, it is the same problem.
Any thoughts or help?
Ps. I´ve reinstalled the usb driver (1.167) and the firmware is 101. Routing on TotalMix is ok. Listening on Sennheiser HD 280 Pro. All on Windows 10, Dell laptop.
Re: Noise on Babyface Pro
You have all the tools to provide meaningful numbers, so do! A BF Pro with no inputs, PAD off, gain 25 dB will show an RMS level of  -99 dB , and Peak level of -89 dB in the TotalMix level meter.
If yours is significantly higher it is defective.
