Topic: UfxII ff800
Hi.
I have 2 ff800,
And i’m thinking buy ufxII
To be mi main sound board,
And use the ff800 as ad da converters and preamp,
How can i control the phantow power of ff800 with this set up?
Beat regards
RME User Forum → FireWire & USB series → UfxII ff800
Hi.
I have 2 ff800,
Beat regards
1. by pre-configuring the two FF800 and then use it in standalone mode (with proper settings)
2. or by keeping all recording interfaces connected to the PC (1x by USB, 2x by Firewire)
- you can select either the recording interface in the TM FX instance
- or open three TM FX instances, one for every recording interface
This is the most flexible solution because you can adjust settings at any time.
