Topic: XLR Balanced output
Hi all,
Been using my ADI-2 DAC over 5 months. Absolutely loving it. I'm recently fiddling the reference level setting of XLR Balanced Out. I found higher output level gives my loudspeaker a beefier sounds of my liking, hence I'm considering reference level of +13dBu.
Just wondering if that 6dB extra at XLR Balanced out do contribute additional voltage giving a 6.9 volt (RMS)? or voltage will remain at 3.46 volt (RMS)?
2 (edited by ting92 2019-03-08 14:21:37)
Re: XLR Balanced output
Just found the answer in user's guide.
Qoute
19.3 Line Out XLR
The ADI-2 DAC has two balanced analog outputs that can operate at levels up to +19 dBu. The
short circuit protected, low impedance line outputs are available as XLR jacks on the back of
the unit.
Unqoute
Didn't know the difference between dB and dBu before. Learnt something new today!
Qoute
19.3 Line Out XLR
the unit.
Unqoute
This link is very useful:
http://www.sengpielaudio.com/calculator-db-volt.htm
smile
Hallo Ting!
Beefier Sounds ja?   Funny.  That was MY first impression of the ADI-2 as well!!  smile
You sound like a Good Candidate for using the Auto-Ref feature of the ADI-2.   Auto-Ref is a "Big Deal" to me because IT does all the "Level" Calcs, and gives YOU an Optimized SNR as well!
Enjoy your new ADI-2!   Man...It has a certain Magic about it...:)
Cables:  Red, and White Ones.
Speakers:  Yes
