Topic: DSP and sound quality
I use Roon for playing music, which also has DSP, and if I apply a set of filters in the RME DAC (and no filters in Roon) and compare that sound to the same filters in Roon but no DSP in DAC it's quite easy to hear that Roon sounds a little better (there is a little harshness in the sound when using DSP from RME).
I would assume that this is because extra work inside the DAC, which in turns generate electronic noice which affects sounds, but it could also be in software, in which case it might be possible to solve in a firmware upgrade.
Anyone else noticed this?
