1 (edited by jiw 2019-03-17 21:15:52)
Topic: PEQ filter type for B5 changes to shelf after enabling w/ 'EQ+B/T+Ld'
The filter type for band 5 of the PEQ for the active output is reset to 'shelf' every time the PEQ is enabled using 'EQ+B/T+Ld' after having been disabled.
Firmware is DAC 26/26.
EDIT: Only occurs when using 'EQ+B/T+Ld' to enable PEQ.
Re: PEQ filter type for B5 changes to shelf after enabling w/ 'EQ+B/T+Ld'
That is the 'encoder -1 on power up' effect that we talked about via mail in test version 26 (and nothing for the forum). We are working on a new firmware.
From the description you gave in the mail, I really could not make the connection.
Anyways, if I experience any further issues with test versions of the firm ware, I will inform you via mail.
