Topic: Totalmix routing, sound to low to outboard compressor
have problem with the loudness going through and out my totalmix.
i have logic and use the i/o plugin on a snare channel. have rme ff400. the compressor gets sound, but to low.
in logic the snare channel shows loudness - 10dbVU. on my compressor it shows -20dbVU. not much signal arrives at the compressor ...
i have rme ff400 output 3 set to +4dB.
i can encrease the output volume on my logic i/o plugin maximum +12 dB and than more signal gets to the compressor but by than the totalmix output shows red/digital clipping. and even than my compressor, when set to 20:1, max. attack show just about 5dB GR on a snare!
do you have your hardware outputs within totalmix always at "0"?
i got no clue what i am doing wrong here ... any help welcome!
