Topic: TotalMix Remote Group Fader bug?
We are setting up for a live tv broadcast this week and intended to dispense with a large format mixer in favour of a MADI setup controlled by totalmix for iPad. I'm currently testing the software without a MADIface and was disappointed to discover the Groups fader function doesn't seem to work on Totalmix Remote. Mute and solo are fine but the fader function isn't. The mix entails 40+ channels of orchestra & choir.
We are running 1.16 on an iPad Pro on iOS 12.2. I note that fader groups and the temporary f-button work fine in TotalMix fx but not on Remote. Later we will try setting up a fader group in the OS X version of Remote and then control it on the iPad in case this is a workaround.
Our only other option is to do the broadcast on OS X using a trackpad which is not ideal, or plug the MADIface xt straight into the iPad (if it works in class compliant mode?) but then we can't record more than 22 channels!
Some advice or even a bug fix before the dress rehearsal on Friday would be amazing if at all possible...
Incidentally is it not possible to control more than 4 groups of faders on TotalMix fx?
www.eastwoodrecords.co.uk
