fripholm wrote:Are you sure Totalmix uses that much of your VRAM?
On my i9 system it's using barely 20 MB of the graphics card's RAM in D2D mode and about 6 MB with D2D disabled (then only when the window is open). With about 30 active channel meters, the GPU load doesn't even reach 10%. In this case a lot of this may have been used by the DAW as well. I have a GTX1050Ti - usage numbers are from GPU-Z.
System RAM usage of TMFX itself is about 23 MB (reading from Windows 10 task manager).
I guess when I look directly in task manager it shows Totalmix is only using 2-8% but there are other processes seemingly linked to Totalmix that bring that percentage higher. Like right now, total mix is only using 3% but my total GPU usage is at 20%, when I close Totalmix GPU usage is around 3%.
The other processes are "Desktop Integration" (11%) and "Desktop Window Manager" (6%), but when I close Totalmix those processes fall off hard bringing total usage to 3%.
It also seems to be affected by what screen I have Totalmix on, usage is higher when the window is placed on my 4k screen as opposed to my 3440x1440 or 1080p screens. Maybe I'll have to get a GT 1030 to drive my 4K display and run Totalmix on that.
