Topic: visible channel count ?
Hi i have just installed my ray dat card and would like to use s/p dif and aes inputs. And use the adats for outputs. But the card only shows 32 in and out instead of 36 in and out ? My old hammerfall was straight forward in this respect. Please dont forward me to total mix its far too complicated for me and i dont need or want it. How do i get my missing in and outs? Thankyou.
Re: visible channel count ?
What daw do you have ? Did you eventually forget to choose all ASIO ports ?
In Cubase you have select the proper driver and then to choose audio connections for inputs and outputs.
You can disable TM FX if you do not like it by choosing the operational mode "Digital Audio Workstation Mode".
Then you have to perform all routing in the DAW.
Where do you see this channel number? Check the number of active WDM devices in the HDSP settings.
ProTools, I bet...
