Topic: Are the Digital Breakout cables for HDSP9652 and HDSP9632 the same?
Are the Digital Breakout cables for HDSP9652 and HDSP9632 the same? Could I use BO968 or BO9632 for the HDSP 9652 digital breakout? I prefer AES, but spdif would work too.
From page 86 in the hdsp9632_e pdf
Pin assignment of the 9-pin D-type connector, breakout cable SPDIF / AES
Note: The digital breakout cable is identical to the one used in the DIGI96 series.
1 GND
2 SPDIF Out +
3 SPDIF In +
4 AES Out +
5 AES In +
6 SPDIF Out -
7 SPDIF In -
8 AES Out -
9 AES In -
I couldn't find the pin assignment in the manual, but I found another post
And from Matthias Carstens
https://www.forum.rme-audio.de/viewtopic.php?id=28698
Re: HDSP9652 DSUB pin assignment
Pin   Name              Pin    Name            Pin     Name
1      GND                4       AES Out +      7      SPDIF In -
2      SPDIF Out +    5      AES In +         8      AES Out -
3      SPDIF In +       6     SPDIF Out -     9      AES In -
Re: Are the Digital Breakout cables for HDSP9652 and HDSP9632 the same?
doesn't look like they are
https://www.forum.rme-audio.de/viewtopic.php?id=27958
Re: BO-968 AES/EBU with 9652?
ADAT Sync connector
Pin   Signal             Pin     Signal
9      SPDIF In +       5       SPDIF In -
6      SPDIF Out +     1       SPDIF Out -
They are not compatible.
The BO9632 breakout cable is the analog i/o+midi, not digital audio i/o
The BO968 is a pure digital i/o - with duplicate 2-wire and 3-wire AES or S/PDIF connectors (AES or S/PDIf protocal selected from Hammerfall DSP settings dialog)
HDSPe AES + HDSPe RayDat + HDSPe MADI
ADI-2 mk.1 x2 + other converters
Cubase + VEP
Thanks for your reply. There are 2 breakout cables for the hdsp9632. One analog, one digital. My question was about the digital breakout cable.
