Topic: Bassy muffled sound through interface
I have something I'm not sure what to make of.
If I connect an audio source (e.g iPad playing a video) directly to a powered speaker through aux cable, I get a normal clear open sound.
If I connect the same iPad with the same cable to my Fireface interface (FF 400) connected to the back inputs 5/7 and then routed internally to the output An1/2 through total mix, with everything gainstaged properly at unity, I get a very muffled sound.
I tried changing the +4/-10 settings of the 5/6 input but that didn't change anything. And I realize the audio is taking a different ADDA path in this setup but the difference here is drastic I can't attribute it to just that.
Anyone experience something similar or has an idea of what could be going on?
Thank you
