Topic: Bit-transparency in Cubase 10 mixer
Hi Guys!
Can somebody here help me troubleshoot a bug in Cubase 10? I'm pretty sure it's only in the monitor path. The reason i'm writing in this forum is because the ADI-2 Pro bit-test is perfect for the purpose.
So - if i import the 24bit test file and play it back, it passes .. but as soon as i add 1 or more empty tracks, it fails ?! .. If i render out the session and reimport it into a new empty session the test passes again.
I did a loopback recording of the output, and it seems that every other sample in the right channel has the LSB toggled on - which surly can't be right!
For what it's worth Cubase 6.5.5 works perfectly, so i'm assuming it's a bug in later versions of Cubase, and certainly Cubase 10 Pro.
best,
Rune / FishCorp
Copenhagen, Dk
Producer / Engineer / Composer
RayDAT > 2 x ADI-8 QS | AES+SPDIF > ADI-2 Pro
